Supertech valves amd valve seals
Old Oct 10, 2024 | 01:50 PM
Kimoneail30's Avatar
Default Supertech valves amd valve seals
Rebuilding my gsr head with all supertech parts but for some reason when it comes to my valves and valve seals there's some play plus a small gap between the two wondering if that's normal
Old Oct 10, 2024 | 07:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Supertech valves amd valve seals
What is the part number for the valve seals that you have ?
Old Oct 11, 2024 | 12:08 AM
VS-H5.5I-8 is the part number
Old Oct 11, 2024 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Was there resistance on the valve when you first inserted it into the valve guide and through the stem seal ? If so, then they are correct. If not, it is possible that even though the part number suggests that it is for a 5.5mm valve stem diameter, they may be mis-packaged and in fact are for non-VTEC (6mm) valves.
Old Oct 13, 2024 | 05:55 PM
Yea there was resistance when I tried to put the valve into the guide but took it to the machine shop and got that fixed but didn't take the seals with me when I did it
Old Oct 13, 2024 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I may not have been clear enough... resistance through the guide is not what I meant. With the valve stem seal installed, when you begin to slide the valve tip into the guide and ultimately up to the valve stem seal, pushing further should cause some resistance as the valve tip passes through the seal. If the hole in the valve stem seal is too large for the valve, there would be no resistance when the valve tip passes through the seal.
Old Oct 17, 2024 | 07:34 AM
Sorry I get it now when u first slide it on there is definitely some resistance but after loose
Old Oct 17, 2024 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That is normal.
Old Oct 21, 2024 | 11:03 PM
So that gap between the seal and stem is normal won't oil leak or will the valve steam expand over time with heat
Kimoneail30
Oct 10, 2024 07:54 PM
VSBB6
Apr 17, 2006 06:13 PM
menkio
Jul 23, 2004 12:27 PM
sneakychaos
Sep 9, 2002 05:48 PM
