98 hatchback surging idle cel p0505
Old Oct 9, 2024 | 08:00 AM
ayben's Avatar
Default 98 hatchback surging idle cel p0505
just picked up a 98 cx hatchback with the d16y7, on the drive home from buying it the check engine light turned on and it started running like ****, surging idle when warm, and when i give it gas, it drops to 1000rpm and sounds like it wants to die but then immediately shoots back up to 1500-2000 surging, seems like someone’s already replaced the iacv, i also tore it out and cleaned the snot out of it. when i clear the cel it seems to run better for a while, not great, but better, until the cel comes back, then it does it again. any help would be greatly appreciated as this is my first car and i really want to get it running properly, also idk if this would affect anything but it has an oil catch can.
Old Oct 9, 2024 | 11:23 PM
OscarsEKhatch's Avatar
Default Re: 98 hatchback surging idle cel p0505
i would check your throttle body gasket and double check if it’s the correct gasket. manual and auto have different gaskets
Old Oct 10, 2024 | 07:51 AM
ayben's Avatar
i’ve sprayed carb cleaner around the gasket and it all seems to be in check, the idle seems to fix itself every so often, when i cleaned the throttle body and iacv it seemed to get better, but the surging idle comes when the cel turns on, although this time when the cel turned on it wasn’t surging the whole time, the idle dropped back down, and wouldn’t come back, leading me to think it’s the iscv intermittently working?
Old Oct 10, 2024 | 08:31 AM
ayben's Avatar
also when i plug the iacv port in the tb it stops surging, so it has to be the iacv right?
Old Oct 10, 2024 | 07:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes.
Old Oct 10, 2024 | 09:40 PM
ayben's Avatar
Originally Posted by JRCivic1
Yes.
just ordered the part hopefully shes good to go
Old Oct 11, 2024 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Genuine Honda ?
Old Oct 13, 2024 | 07:45 PM
ayben's Avatar
Genuine Honda ?
no lordco wanted $200 canadian for it so i just thought i’d try a knockoff, so far it’s been a huge difference, also found a pinhole leak in a hose and the high idle and surge is completely gone, i’ve taken it on a fair drive and it’s had probably 4-5 hours runtime today with 0 issue, idle dead on and zero stutters, FIXED!
IA95civicDX
Nov 18, 2010 10:19 PM
JUICED COUPE
Jan 7, 2010 02:08 PM
TylerC
Aug 18, 2005 10:28 PM
