H22a1
That ECU doesn't recognize the CKF sensor, so it is not necessary to wire it up. The JDM H22 distributor has all three sensors inside... all you will need is a distributor conversion harness. The JDM distributor has the CKP, CYP, and TDC sensor inside.
do you know what type of conversion harness
So far, you haven't truly provided enough information for anyone here to truly help you. Let's start over...Please post a photo of the engine harness plug for the distributor and the plugs on the distributor... and state your distributor housing number (it is stamped on the edge of the housing: "TD-XXU" where the "XX" are two digits between 1 and 9).
Dr Tweak
Nov 11, 2006 01:50 PM
