Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
P2647 causing limb mode and vehicle shuts off. How to disconnect vtec
Old Oct 2, 2024 | 05:28 PM
Rastech29's Avatar
Default P2647 causing limb mode and vehicle shuts off. How to disconnect vtec
Just bought this vehicle initially I was getting p2647 code and vehicle drove ok for a day. Since then if I drive the vehicle for 2miles vsa lights comes on and engine stops. I believe vehicle is going in limb mode. What I have done so far to fix.
Step 1 replaced the solenoid gasket. (Got new p2649 code and random misfires. Engine oil is burning was almost empty.)
step 2 replaced all the coils and plugs did oil and filter change (drove 4km same issue vehicle went in limb mode. Again. System was still recording misfires)
step 3 added muzzuler mod 100amps resistors. And replace oil pressure switch(Drove for 4km and same issue vsa light came on and engine goes in limb again and now I only see p2647 code.)
vehicle is burning engine oil as I do see blueish smoke and lots of moisture. Not sure why p2647 is still showing even after replacing the sensor and oil level are good. 5w20 mixed with Lucas engine repair.
I am thinking vtec is causing issues so is there a way to disconnect vtec. So I can at least drive the vehicle for more than 4km. And run the vehicle with all 6 cylinders as well.
Thanks
Ps I paid 6k for this vehicle have only 191 kilometers. Need to fix it so it last me through cold Canadian winter.
morglum
Honda CR-V & Element
Mar 25, 2015 01:57 PM
MorthlandAccord
Sep 19, 2014 07:14 PM
tdgcgpgsr
May 13, 2006 11:43 AM
sivik2nr
Mar 14, 2003 09:13 AM
