Root and size problem
Old Oct 1, 2024 | 03:46 PM
civiclizedguy's Avatar
Default Root and size problem
I’m in my dual enrollment welding school and I have a quick question about 2 things.
welding 7018 3/32 and 1/8 running 85-90 and 115-120 amps
I used 1/8th on a filler weld flat but I notice when I lay my root the slag is hard to get off more than my 2nd passes+. I also notice this on my vertical 3/32, I do everything right holding it on sides and angle yada yada but it doesn’t bacon itself. What’s wrong?
and on my verticals my welds come out wide, their fat. I fixed the pointing in the middle but I can’t find out how to make them skinnier and I usually use a zigzag pattern. Thanks.
Old Oct 2, 2024 | 08:24 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Root and size problem
Regarding the root pass, how much of the mill scale are you grinding off?
What thickness plate are you welding?
Why aren't you using a 6010 for the root?
Second question, tighten up the zigzag. You just need to touch the toes. If you have a 'dig' setting, play with that a bit.
Old Oct 18, 2024 | 12:14 PM
I grind all mill scale off clean and shinier and smoother than my brain
we run at the school bout any scrap plates we have which are usually 1/4 inch and more
our teacher doesn’t want us to use the 60s yet because the 70s are beginner friendly etc
I’ve gotten a bit better I’m kinda natural at welding sometimes so like a week after I was able to lay some cashmoney
Tyson
Suspension & Brakes
Mar 25, 2007 08:20 PM
ladius
Welding / Fabrication
Oct 23, 2005 01:11 AM
OverCorrupt
Oct 4, 2005 03:26 PM
Matt Groove
Honda Motorcycles
Jan 17, 2005 11:06 PM
poison
Sep 5, 2002 02:42 AM
