96-97 honda del sol Timing cover rubber gasket seal
Hello all my timing cover has been leaking a lot and i went to replace everything only to realize half the gaskets in the timing cover are missing and what’s worse they’re completely discontinued by every part store!!
but i also found very very similar gasket sets available under different years and models.
does anyone know if the gaskets overlap from different years?
ebay says that gasket seals from B18’s won’t fit a B16A. but i’ve looked and the picture appears literally identical. i’ll post a photo of the gasket set im looking at vs what the set looks like on a B16A.
and if they aren’t the same how did anyone get a hold of the inner gasket cause that’s the one that literally doesn’t exist anywhere no matter where i look!! has anyone found success in literally
just melding they’re own gaskets?
