Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Does the ECU Store HVAC Codes?
Old Sep 25, 2024 | 02:26 AM
web35's Avatar
5 Year Member
Default Does the ECU Store HVAC Codes?
I have a 2008 Civic SI with a Kraftswerks surpercharger that has an intermittant shutdown of the A/C compressor system. I THINK that I've narrowed it down to an over pressure shutdown due to the extra heat generated by the intercooler. Can a Honda dealer with the Honda scan tools pull codes or logs from the ECU that show HVAC events?
Thanks
Old Sep 25, 2024 | 07:45 AM
hondamark35's Avatar
Default Re: Does the ECU Store HVAC Codes?
2008 should be CANBUS...
The HDS that the dealer uses should be capable of looking at HVAC codes. But there are plenty of bi-directional scanners on the market that can do this too. I paid around $200 for mine and have used it a few times to find HVAC fault codes and run diagnostic tests. not sure what your local dealer charges, but I bet picking up a scanner for yourself is more cost effective in the long run.
Old Sep 25, 2024 | 07:56 AM
web35's Avatar
5 Year Member
hondamark35
Thanks for the info. Doing it myself is much more my style but I didn't know where to start with buying a scanner. Would you mind pointing me in the direction of what you bought to save me some research? Brand and model would be very helpful.
Thanks
Old Sep 26, 2024 | 04:00 AM
Originally Posted by web35
hondamark35
Thanks
I went with the Foxwell NT510 Elite. I wanted physical buttons- not a touch screen, compact size, and didn't need the bluetooth/wireless feature, which tends to add to the cost. That was a few years ago and I think there are some new models that improve on the 510 for about the same price, like the NT650 Elite.
I have a more basic code reader from Autel, but I have heard other people recommend their bi-directional scanners as a good budget option for home use.
I hear a lot about Launch brand diagnostic tools, but I'm not really up to speed on them.
Old Sep 26, 2024 | 05:22 AM
web35's Avatar
5 Year Member
THANKS!
Lance Darling
Jun 18, 2019 01:36 PM
ashoka
Oct 24, 2005 07:29 AM
