99 EJ Civic EX Coolant Leak
Old Sep 18, 2024 | 01:44 PM
EHE's Avatar
EHE
Default 99 EJ Civic EX Coolant Leak
Hey, I have coolant leaking from the front water outlet housing where the top radiator hose connects to and haven’t been able to find information on fixing this issue. So I was wondering if anyone knows if it’s just a matter of replacing the housing and putting Honda Bond and torquing the two bolts that hold it will fix that issue along with bleeding the coolant system afterwards. Any insight would be appreciated thanks in advance.
This is exactly where the coolant is leaking from
Last edited by EHE; Sep 18, 2024 at 02:01 PM. Reason: Changing the tittle description
Old Sep 18, 2024 | 06:11 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 99 EJ Civic EX Coolant Leak
drain radiator and then remove housing. Clean mating surfaces on housing and cylinder heat. Apply Hondabond sealant and reinstall housing. Add coolant and bleed system.
** I would replace that upper radiator house as well. Get the correct size hose because that one will likely burst any day.
adamg1717
Honda Civic (2001 - 2005)
Mar 29, 2023 05:54 AM
civic05tx
Feb 1, 2019 09:00 AM
AllenLogue
May 25, 2018 05:00 PM
myshelly2010
Apr 18, 2013 02:58 PM
moncherris_em1
Mar 28, 2011 05:37 AM
