Kswap or resleeve a b20
So I have a question and couldn’t find any good threads. I want to know what would make my life easier. I’m looking to either resleeve my b20 block or swap a k24 into my rd1 crv. What is the consensus on this and what do y’all recommend
If your CRV already has a "B" series engine in it, and the engine is damaged... why would you re-sleeve the block instead of replacing it ? Re-installing a B20 block that essentially matches what you currently have would be MUCH easier to accomplish than a complete "K" swap.
people forget that in order to have a good running k swapped car, you will need a good engine management setup, which is usually $1k and up
