Crank no start NEED HELP ASAP
Old Sep 13, 2024 | 07:47 PM
finny's Avatar
Default Crank no start NEED HELP ASAP
I’ve bought a 1998 ek4 vtir that recently has had an intermittent starting issue. At first it was that the ecu had been faulty, I’ve had it completely retraced & all capacitors replaced as well as the ic17 chip I also have a brand new main fuel relay. The car ran well for about 3-4 weeks
ECU IS A PR4 from an integra that has been chipped for manual and vtec ect
but is now having that same issue come back. In the morning the car would prime and have a strong crank but no start and weirdly the car would start from a push start. And the days I left the car home by the time I had come back from work it would start up first crank with a little stumble but eventually level out and run like normal, there is an off chance that it will start in the morning but it usually stumbles and shuts off so I have to start it up again
CAR WILL RUN AND START NO PROBLEM AFTER THE FIRST INITIAL START
the last 2 times I’ve had this car push started the engine light had come on and it won’t rev past 3500 (which I assume is a safety feature) I also can’t find and sort of an obd port anywhere
car has had a major service in-between issues
  1. spark plugs
  2. fuel filter
  3. new dizzy (eBay certified)
(I have an extremely basic tool kit) due to having all my tool at work
If anyone has any ideas on where I should start I’d be very grateful cheers
khabibul35
Sep 17, 2014 08:37 PM
LeeTrucker
Mar 28, 2009 10:59 AM
corked1260
Nov 19, 2007 08:28 AM
89sicivic
15
Jun 1, 2006 07:51 PM
CivicHP
Jun 1, 2005 02:27 PM
