2000 civic sedan dies when warming up (d16y7)
Hi i have an issue with my 2000 civic dx sedan, when it starts to warm up the engine cuts off and wont come back on till the entire system is cooled down. When this happens i’ve came to realize it loses spark completely, and when checking the power wire to the distributer i’ve noticed that once the issue starts occurring the wire loses ground. Ive already replaced my ignition coil ,main relay, all spark plugs crank shaft position sensor and my fuel pump is in great shape, I've also only gotten a code for an o2 sensor if anyone has any clue what it could be id be very grateful for the help
I already changed the coolant temp sensor that goes to the ecu very recently, within about a month. Also update i just changed the ecu to one out of another civic same parts number and still hasnt fixed the issue
Today when i was working on it i noticed the coolant temp sensor had oil all inside of it(likely from when i removed the distributor for the head gasket replacement) so im gonna replace it
Ehaynes
13
Aug 1, 2023 04:16 AM
Lupien_life
May 11, 2021 02:08 PM
dwillms
Sep 16, 2014 06:50 PM
braulio jenosid
Oct 20, 2012 04:53 PM
