Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
castor issue on a 2001 Civic dimension sedan 5 speed
Old Sep 7, 2024 | 01:39 AM
Phillipinecivic's Avatar
Default castor issue on a 2001 Civic dimension sedan 5 speed
Are there both horizontal and vertical sub frame bolts on this car? I ask because I see 2 vertical bolts on each side only.I am disabled with a severe rotator cuff on my left and frostbite damaged feet ankles and legs so not easy to get down and look underneath.broke a tie rod endon the passenger side.It was the inner.Replaced that rough set toe and drove it home.Replaced passenger strut top bolt and ground bottom.Gave me back an inch plus caster.replaced all tyres with new same size as factory option tyres.I will also replace the bottom bolt on this strut to see if I can get more castor .I know i will get more camber.And if I can adjust the subframe I think I can gain at least 1/2 inch positive castor on the passenger and mabey 1/2 in minus castor on the drivers side so it will drive straight with an air set on all 4 wheels and a toe set on the front.A heraty thanks to whom ever reads this and replys to me.I know a big project for a disable 63 yera old guy but I am confident
yayizzil
Dec 17, 2008 06:01 PM
ricecooker415
Northern California (Sales)
17
Jul 7, 2008 06:17 AM
Tyson
Feb 19, 2004 04:35 PM
Cryptopsy
Mar 31, 2003 07:50 PM
