Just a few questions on installing a front sway bar on an EG dx that came with no sway bar. I did a search and found nothing.
1. Are the provisions for SB endlinks on the lower control arms?
2. Do all non sway bar civics come with the holes to mount the bushing and clamps to the body of the car?
If it didn't come with a sway bar, then the lower arms do NOT have end link attachment points. You need different lower arms if yours are still stock. Any 94-01 Integra will work.
Your subframe DOES have the 2 threaded studs and 2 threaded holes to mount the OEM sway bar brackets. You need two of each of the following nuts and bolts.
