Motor Mount Issue and NVH
Old Sep 3, 2024 | 08:25 PM
CWFL5CTR's Avatar
Default Motor Mount Issue and NVH
I just got my ITR and immediately noticed the huge amount of NVH that reverberated through the cabin generally at low rpms, especially when the A/C is on. Upon close inspection I noticed the driver side engine post is crooked on the block (supposed to be that way?) and as such it sits crooked in the bracket. I can see the bolt that goes through it is angled in the engine mount and the rubber caps are askew due to the angle. The engine doesn't move when blipping the throttle. Not sure if this is causing the NVH, but it just doesn't look right the way it sits. Any help is appreciated.
Old Sep 4, 2024 | 07:09 AM
aw614's Avatar
10 Year Member
Loved
Default Re: Motor Mount Issue and NVH
It shouldn't be slanted like that. Are you able to support the motor and loosen all the mounts and reset them?
Old Sep 4, 2024 | 10:21 AM
Chrisfrom1986's Avatar
It's likely the wrong post mount bolted to the block.
Old Sep 4, 2024 | 12:19 PM
CWFL5CTR's Avatar
Are all the posts the same for the integra?
Will this work: https://www.ebay.com/itm/17644248007...Bk9SR5LE7uq3ZA
Old Sep 4, 2024 | 03:58 PM
CWFL5CTR's Avatar
Are there other posts that exist that have an angle like that?
Old Sep 4, 2024 | 05:46 PM
CWFL5CTR's Avatar
Figured it out. There is a snapped bolt. Looks like the motor has to come out!
Old Sep 4, 2024 | 06:20 PM
One of the post mount bolts?
Old Sep 4, 2024 | 10:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Ouch.
Jdm_JavieR
Oct 7, 2010 02:55 PM
arielb1
Mar 14, 2005 08:36 AM
LiL accORd RideR
Jan 21, 2005 03:15 PM
95whitegizzer
Jun 20, 2004 07:50 AM
CIVIX
Mar 18, 2002 06:03 AM
