Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
no spark,no crank
Old Sep 2, 2024 | 03:58 PM
johnsoto2k's Avatar
Icon4 no spark,no crank
So i have a 06 accord lx 2.4l fl dohc 4 cyl
i replaced the head gasket and other gaskets as well to even get to that point. the initial issue was coolant in the combustion chambers and one hell of a leak around the valve and head. everything was fine at first until i cranked it and it would accelerate on its own before it shut off. obvi i messed up the timing took off the cover did it again about 3 times , because i find out there is no spark anymore and now doesn't start up like it did the first time. i thought hey maybe i damaged the crank shaft sensor so i replaced it and nothing double checked every connector nothing checked power fuses and air even fuel pressor and everything was good. i checked the coil packs and they were good . i found that the signal voltage to the coils wasnt present i have constant power and ground but no signal . the relay is good and there is continuity between the connector and the relay and the connector and the ecu which sends the signal so my whole question is why am i not getting spark despite no breaks in the cables and no connector having issues.
Agpilot
May 4, 2020 08:34 PM
Billy333
Honda Fit
Apr 16, 2020 03:46 PM
Jeremy Harris
21
May 2, 2016 10:58 AM
peter_x
Sep 25, 2009 03:05 PM
A lil 2.3l action
Jul 1, 2008 04:07 PM
