Help loosening tension on timing belt
I’m currently replacing the head gasket on my 2000 civic LX and am trying to release the tension on the timing belt so i can pull the head off, but I’m stuck. I see where the tensioner bolt is at but I can’t seem to get a socket on there because it’s so tight. I did try removing the power steering pump but still didn’t have enough room to get to the bolt. Does anyone know an easy way to get to it, or how they’ve done it before? Thanks.
Usually you get a ratchet on this bolt from inside the wheel well. Make use to use a 6-pont socket, cause it's bad news if you round the head off. Happened on my B18. Had to drill the entire head off to remove the bolt.
tur3oDC4
Dec 4, 2005 09:12 PM
arielb1
Jul 31, 2004 10:05 PM
