H22 crank but no start
hi guys quick question I have a 97 civic with a jdm h22a1 swap and I'm using the civic original harness i just had to extend some connection. Everything connects and i have crank but it's not starting. I'm running a internal coil distributor but I'm not getting power to the distributor. I am getting fuel and I'm running a jdm ecu with it and still no luck. Idk if im using the correct distributor for it and idk what it could be any help would be appr
You said there is no power at the distributor. The distributor plug on the '97 Civic engine harness is different from the distributor plugs on the JDM H22 distributor... did you rewire this junction yourself or did you purchase an adapter harness ?
98__SH
Jan 11, 2018 10:05 AM
jacoblytle
Jun 29, 2014 04:36 PM
