voltage to turn signal no flash
Old Aug 26, 2024 | 03:42 PM
jackderf's Avatar
Default voltage to turn signal no flash
when i have my right turn signal engaged i have volts to the socket, i grounded it to chassis, replaced the socket. why on earth would it not light if it’s getting voltage? the v is jumping around but i assume it’s normal because of the whole blinking thing
Old Aug 28, 2024 | 04:28 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: voltage to turn signal no flash
have you replaced the 1157 bulb? Does it work with just the lights turned on, not turn signal ??
Old Aug 29, 2024 | 06:13 AM
jackderf's Avatar
i hooked up the socket to the battery and it lights up perfectly, i have noticed i’m getting 12v out of the signal stalk for both left and right, then at the socket i’m getting 2-7v on the right and the left is stable 11 then 0 goes with the blinking
Acethriller
Lighting
Jan 4, 2014 07:58 PM
Gvis420
Dec 14, 2008 10:19 PM
nbcivic
Nov 6, 2007 11:59 AM
g2b2
16
Jun 6, 2007 12:46 AM
