Ac system
Old Aug 25, 2024 | 02:03 PM
Borsch's Avatar
Default Ac system
Installed a new ac system in my 90 hatch
everything is new and I’m running r134.
excavated the system and it held vacuum for 24hours. Went to charge and it took one 12oz can. Went to charge with another can and for some reason won’t empty out. Compressor fan kicks on but compressor won’t. Checked the relays and jumped the high pressure switch. Compressor won’t kick in
hi side and low side pressure is reading the same at about 100psi
I’m not sure what’s happening
note I ran a wire to a12v source to see it the clutch engages which it does
Old Oct 20, 2024 | 07:30 AM
JMZ400's Avatar
Default Re: Ac system
I've had to heat my second can with hot water in order to get enough in for the system to kick on. If you've already jumped it, I'm not sure what to say.
adirsabag
Apr 23, 2022 03:13 PM
PandaGurl Pandy
Honda CR-V & Element
Mar 30, 2021 10:06 AM
REDEM1FTW
10
Mar 27, 2012 10:19 PM
Bigrome34
21
Aug 6, 2010 10:10 AM
4doorcivic16
May 14, 2010 04:39 PM
