Tail Light Wiring Problems
Old Aug 21, 2024 | 05:52 PM
ddlangenfeld's Avatar
Default Tail Light Wiring Problems
Please help! Currently unable to drive my 97 Civic EX. Upgraded to clear tail light housing. Drawback of this is the halogen bulbs I had for brake lights were yellow (shined red through previous red housing). So I decided to upgrade to LEDs. Problem is that when my night time running lights are on, my LEDs stay only one brightness even if I click the brake pedal.
Now I’m pretty sure I understand the basics of the circuit. Black cable for negative, green white for brake light, and red black for tail lights. I also know the circuit still runs fine considering when I use halogens they work normally getting brighter when I brake and my night running lights are on. I know this is because they are dual filament and can run two circuits unlike the red LEDs. However, I don’t know how to make a circuit that will let the LEDs work properly. I originally thought of using resistors to make the running lights work at only 80% of the power they are designed to so that when the brakes are pressed they will run the full 100% and look brighter. However it appears from testing that both the green white and red black cable both supply power for running lights, and for brake lights! So I cannot isolate one of the two power sources. Any ideas?
tall007dfw
Nov 30, 2018 08:54 PM
glockjs
Sep 28, 2013 12:59 AM
Frstyl838
Lighting
Aug 7, 2012 07:51 AM
toolbox21
Mar 17, 2009 08:31 PM
rewerbcrx
Sep 4, 2006 03:17 PM
