Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Accord SE - Can't Remove Front Rotor
Old Aug 19, 2024 | 01:20 PM
KnightRider66's Avatar
Default 2006 Accord SE - Can't Remove Front Rotor
Not sure what's going on. Removed the 2 screws and the spindle nut, but still no movement. Am I missing something?
Old Aug 19, 2024 | 01:36 PM
Ryanthegreat1's Avatar
Default Re: 2006 Accord SE - Can't Remove Front Rotor
Put the spindle nut back on before you pop the bearing apart.
All that rust is going to make removal a huge pain in the ***. Big hammer or an air hammer and beat on it until the rust starts to break apart.
Old Aug 19, 2024 | 03:06 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Or thread two M8 x 1.25 bolts into the two indicated holes to push the rotor off. Turn the bolts 90 degrees at a time.
Old Aug 19, 2024 | 04:56 PM
Thanks to both of you for the information. Ended up putting two bolts through the caliper mounting holes and pushing the rotor off from behind.
The white gunk around the outside of the bearing was fairly soft -- maybe salt deposits.
Old Aug 20, 2024 | 01:29 PM
jfreakofkorn's Avatar
looks like the rotor can not be saved
i would give it a go or pop the heck out of it w a heavy hammer
probably stuck on there for some time
its like one of those wheels that wont come off unless you kick it or hit it w something blunt
Tuan Huynh
Paint and Body
Dec 4, 2020 01:26 PM
sricke
Apr 15, 2019 06:52 AM
The Illest CD5
Feb 18, 2014 04:26 PM
Atariwarrior
Jan 15, 2007 08:07 AM
jdm-hondacura
Nov 17, 2006 05:24 PM
