Misfire on cylinder 4
Old Aug 11, 2024 | 12:25 PM
Kiccat's Avatar
Default Misfire on cylinder 4
I'm new here btw, so I may not understand some slang around these forums. The car im troubleshooting is a 1998 honda civic ex coupe (d16y8) pretty much stock: i brought it almost 2 years ago. Straight to the point, a week or 2 ago I got a weird misfire on cylinder 4 After I fix some exhaust leaks. I change plugs about a year ago, change wires 3 months after the plugs and ran fine until now. I did more work before this like injectors and some coolant hoses and some suspension stuff work. Anyway I check the plugs, wires, compression (1: 116 | 2: 115 | 3: 120 | 4: 117) and check spark. All seem good, but I took apart the distributor just for peace in mind and saw corrosion on the cap, rotor and ignition coil. So I replaced all for those and still get a misfire on 4. I do hear some kind of spark noise from the distributor. I did check valves and no cracks or holes. I kinda lost at this point.
Old Aug 12, 2024 | 12:56 PM
Heysoos's Avatar
Loved
Community Favorite
Default Re: Misfire on cylinder 4
Sounds like you've covered quite a bit. Have you cleared the code, after the parts replacements, and it re-appears again on #4? If so, swap the #4 injector, with a different one, and test again.
Old Aug 12, 2024 | 02:50 PM
Kiccat's Avatar
I did clear after. It would run fine for awhile then slowly the misfire would come back. Ill try switching the injectors after i replace the distributor. The reason I'm changing the distributor, the pervious owner installed some Amazon junk called "mostplus" like the hell is that?
Old Aug 13, 2024 | 06:44 AM
Kiccat's Avatar
I'm using iridium spark plugs should I switch to original. I switched out my distributor and it seemed to be better (code for cylinder 4 is still coming back). I'm going to switch injectors as suggested. But I think I go back to original plugs
Edit: btw code for multiple multiple misfires went away.
Old Aug 13, 2024 | 02:11 PM
Heysoos's Avatar
Loved
Community Favorite
I don't think there's any worry about iridium spark plugs. Sounds like the distro was a POS. Hoping swapping the injectors will get you an answer.
Old Aug 14, 2024 | 04:36 AM
Kiccat's Avatar
I swap injector from 4 to 1 and misfire moved. Can't believe i was panicking over a defective part. Ill be getting a warranty replacement today and pray this was truly the issue. Also I won't be returning the new distributor since I didn't trust the last one.
Bebo01
Aug 6, 2018 08:09 AM
alpinac1
Jan 21, 2013 08:01 PM
civicxxman
Apr 27, 2008 01:52 PM
Tom123456
Aug 23, 2006 03:13 PM
