Different color connector wires. HELPPP
Old Aug 8, 2024 | 03:33 PM
336leo's Avatar
Default Different color connector wires. HELPPP
I am replacing the rubber groument for the intake temp sensor. How do I know which wires are supposed to connect? They aren’t the same color and this is how I bought the car. There is two greens, one yellow and one red
Old Aug 9, 2024 | 07:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Different color connector wires. HELPPP
If it worked as it is wired in your photo above... re-connect it the same way.
Old Sep 23, 2024 | 11:23 AM
336leo's Avatar
I still have the code so I’m not sure. I checked the resistance of the sensor and it checked out to be good. Could the sensor still be bad even though it’s good?
Old Sep 23, 2024 | 12:06 PM
336leo's Avatar
well nvm I did a continuity test with a multimeter and I got a .699 reading on it so I guess it’s correct.
Old Sep 23, 2024 | 11:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The sensor is a thermistor... which is a resistant circuit. In your photo close to the plug connector, the green wire appears to be bare/damaged. This may still cause an issue, so repair the wiring and replace the IAT connector with a good clean one with healthy wiring, clear the code, and re-test.
Old Sep 24, 2024 | 01:30 AM
336leo's Avatar
ahh okay I’ll get a iat connector pig tail today and try that out. Thanks for the advice
Shmidty
Nov 12, 2021 03:30 AM
redlinez_r_us
May 6, 2008 07:23 PM
Atheist
Apr 3, 2005 04:34 PM
JCracer723
Dec 6, 2003 10:23 PM
