Sold 1988 civic sedan for sale, clean title. B20z T3 turbo setup with short gear Y1 transmission. Chassis has ~300k miles, engine and tranny have less than 100k, and it has 0 miles on the turbo setup.
This was my fun car in college in the early 2000s. I spent a lot of time tinkering with it and it has had a few different setups. It was a locally-competitive Street Mod autocross car, it’s been to a few track days, and I occasionally took it to the drag strip.
It had the B20 in NA form for most of my ownership and it ran strong: low 14 1/4 mile times, super torquey in the just-above-2000 lb car.
I installed the turbo setup and got it running back in like 2008. Then I got a job in another state, moved, and never had time to sort it out. It’s been stored indoors in a shop since then.
It runs and drives, I replaced the fuel pump with a new stock pump Aug 2024.
It’s currently running with the N/A fuel system components: 240cc injectors, stock pump, chipped PR3 ECU. It includes a few not-installed upgrades: DSM 450cc injectors, an adjustable fuel pressure regulator, and a walbro 255 pump. These things will likely need to be installed, then it will need to be tuned for the turbo.
I’m still pretty emotionally attached to it. If it doesn’t go for what I want with minimal nonsense, I’ll just keep it until I have time to sort it.
Engine
USDM B20z2 engine, totally stock, pulled from a CRV with less than 100k miles
Y1 cable transmission
Extra b18b head
Garrett T3 60 trim turbo, probably .48/.60 A/R
Tial wastegate with several different springs
3” Stainless downpipe built and tig welded by me
Extra 3” stainless 90 bend included as well
2” Charge pipe
Can’t remember the manifold or the intercooler builder
Mishimoto EG radiator
Lightweight flywheel
Currently running B18a 240cc injectors, stock regulator, and brand new stock fuel pump installed 2024
Includes DSM 450cc injectors, fuel pressure regulator, and walbro 255 pump (not installed)
Running on chipped PR3 ECU tuned for the NA b20 with 240s
Moroso catch can
Uninstalled exhaust parts: new 3” pipe, new high flow cat, new 3” can muffler
I also have a haltech elite 1500, haltech wideband, and boomslang harness for extra money.
Chassis
DA integra knuckles and brakes
DA integra rear trailing arms and brakes with pretty new trailing arm bushings
DA integra master cylinder and booster
New hawk pads installed
A bunch of bushings have been replaced over time
E30 bottlecap 15” wheels with really old, really used advan A032 tires
Quaife short steering rack kit installed
Koni yellows and ground control coilovers with 8k front / 10k rear rates
New Suspension techniques 22mm rear sway bar
New skunk 2 upper A arms with camber adjustment
Top hats modified (lengthened) to give more travel
Rear strut bar, lower tie bar, and strong bar made by me (oglesport / Ben ogle)
Front raised up so we can get it in and out of the garage
Bumper supports cut way down
Car weighs just over 2000 lbs
Chassis has somewhere around 300k miles on it
Interior
Momo cup VTR seat (FIA 1999) with custom brackets on stock sliders
Si cluster that reads 193k miles
Shifter lengthened on bottom for shorter throws
Aftermarket steering wheel with long extension for tall people
New Autometer Oil pressure gauge
New Autometer boost gauge (not installed)
Rear seats removed, rest of interior pretty much all there
No stereo, speakers or stereo wiring
No heater core
Small, trunk mounted gel battery
A bunch of sound deadening removed
Misc
Extra b18b complete head
A pair of unused kumho 15” tires
Extra distributor
Extra alternator
DA integra AEM intake when it was NA
DA integra 15mm rear sway bar
A bunch of extra bolts, brackets, parts etc
Back in the day with lensos and slicks
During the turbo install
Reason: Car sold
Really nice car, admiring it, truly. Beginner here, hope I'm not disturbing so much, just a quick amateur question, what is this for? I know the theory for the air filter, but what's this smaller one for, when would you add it? Thank you!
