90 hatch swap questions
Old Jul 21, 2024 | 08:37 AM
spuriousjim's Avatar
Default 90 hatch swap questions
I picked up a 90 hatch and want to Kswap. I grabbed a deal on a 06 RSX Type S as a donor. I've searched several forums but still confused on a few simple things.
  • Is it possible to pull the K20z1, 6 speed trans, wire harness, power harness, shifter and cables, ECU into the EF hatch? Can it run stock on its own harness/ecu?( I understand there's fabrication, mounts, conversion harness, axles...etc)
  • Pictures of the donor added, what would you guys pull from the donor? Everything? The RSX runs and drives now, just interior was gutted.
I just want to run the stock engine, ecu and trans in the hatch. No management other than ecu (immobilizer bypass?)
Thanks for any and all help.
Old Jul 26, 2024 | 07:41 AM
Default Re: 90 hatch swap questions
Ok, so maybe my questions are too vague. Let me ask this, would you use an aftermarket harness like Rywire or K-Tuned? Or try and run the swap on the RSX harness?
Old Oct 9, 2024 | 11:57 PM
BatracED6's Avatar
watch this series should answer your questions
Old Oct 10, 2024 | 05:47 AM
Thanks BatracED6! I appreciate it.
CGR214
Apr 19, 2021 09:50 PM
jtsmalley14
K Series
Aug 31, 2020 09:20 AM
danielpak_ek9
K Series
Apr 11, 2014 09:33 AM
Boostdprotegelx
Jan 29, 2009 06:44 PM
johnDX
10
Jul 26, 2007 04:28 PM
