06 civic si crank, no start
I have a 2006 civic si, I did a motor rebuild on it. Before hand it ran just fine besides burning a massive amount of oil (piston rings were clogged) got the motor back together and not it won’t start. I have compression, I have fuel pressure, the motor is in time. So that leaves spark. IT IS getting spark… but not consistently. So I changed out the crank sensor and both cam sensors and it’s still doing the same thing. I looked over the wiring harness and can’t see any damage. That leaves the ECU. There are no codes and everything else functioning as it should. What should I do?
crxcess
Jun 10, 2006 06:05 AM
