Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Trouble getting base model rsx swap to start.
Old Jul 10, 2024 | 07:02 AM
maddoxej8's Avatar
Default Trouble getting base model rsx swap to start.
Swapped a 02 rsx base motor into an 02 civic ex coupe. Car cranks all day long but wont pop off. noid light shows no injector pulse so I test my ecu connections for the ignition circuit and as far as im aware everything checks. power and ground to the ecu where i need it and signal being sent to where the injectors should be. the car isnt running kpro but instead a ktuned immobilizer bypass... in my scan tool it reads "immobilizer: ban". pretty confused at this point and would really like to get the car running. any help is appreciated.
Old Jul 10, 2024 | 07:12 AM
maddoxej8's Avatar
Default Re: Trouble getting base model rsx swap to start.
just to clarify fuel pump is priming and i can hear the main relay click when i turn key to start or run, its as if the immobilizer is not deactivating to allow fuel.
Old Jul 10, 2024 | 07:52 PM
Ryanthegreat1's Avatar
Immobilizer for sure.
TheLaxPlayer
Aug 27, 2014 06:27 AM
HitF8
Jan 15, 2009 01:54 PM
tblango
Oct 3, 2005 08:30 PM
tblango
Oct 3, 2005 08:23 PM
