Fuel line snapped to fuel filter, what to do?
Old Jul 6, 2024 | 03:43 AM
Rasetzer's Avatar
Default Fuel line snapped to fuel filter, what to do?
The fuel line snapped off and I don’t know if I need to replace the whole fuel line or is there another way to go about it? Sorry I’m not car smart lol.
Old Jul 6, 2024 | 05:41 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Fuel line snapped to fuel filter, what to do?
use a tube cutter to clean up that damaged part. Go to local pull-a-part salvage yard and cut off the part with the fuel filter fitting and lines. Stop by the auto parts store to get the appropriate fuel hose and 2 adjustable clamps. Make sure fuel does not leak after repair since the header pipe is literally underneath
Old Jul 6, 2024 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Make sure that the two pieces of hard line ALMOST touch... this way there is no chance of the piece of soft hose slipped over the two hard lines and clamped firmly doesn't slip off one end or the other.
Old Jul 8, 2024 | 02:08 AM
wunfstgsr's Avatar
Loved
Community Favorite
You could use this fitting and go with an aftermarket fuel filter and 6AN line to the fuel rail. I'm not sure if you need the long or short style but just double check. You also need to use a flare wrench on the nut on the bottom of the fuel filter I have these they work great!
SEDY 4-Piece Flare Nut Wrench Set, Offset End Spanner Metric 9 10 11 12 13 14 15 17mm, CR-V Steel Storage Pouch Repair and Remove Nuts on Fuel Tube Hose Transmission Line - Amazon.com SEDY 4-Piece Flare Nut Wrench Set, Offset End Spanner Metric 9 10 11 12 13 14 15 17mm, CR-V Steel Storage Pouch Repair and Remove Nuts on Fuel Tube Hose Transmission Line - Amazon.com
Amazon.com: Hardline Fuel Fitting Adapter Compatible with Honda - Compatible with Acura - Models Civic Integra CRX Prelude (6AN) Short Style : Automotive
This kit looks to have everything you need, This is just an example there is better more expensive kits but you get the idea,
Amazon.com: LABLT Fuel Line AN6 Filter Replacement for Honda Civic Integra B/D Series Tucked EG EK EF DC2 CRX : Automotive Amazon.com: LABLT Fuel Line AN6 Filter Replacement for Honda Civic Integra B/D Series Tucked EG EK EF DC2 CRX : Automotive
justYncredible
Feb 12, 2012 09:23 PM
memphisfuk
Jun 8, 2008 01:20 PM
jaycapz
Sep 23, 2004 09:23 AM
