Valve Adjustment Problem D15 B8
Old Jul 2, 2024 | 09:48 AM
dirt-cheap's Avatar
Default Valve Adjustment Problem D15 B8
1995 D15 B8
At TDC #1 intake valve and I already backed-off the adjustment as far as it will go but I still can't get my .008 feeler to squeeze in there.
Any idea what's happening here?
Old Jul 2, 2024 | 07:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Valve Adjustment Problem D15 B8
Do you have stock or aftermarket valves installed in the head ? Have you recently sent the head over to a machine shop and have a valve job done ? Cutting valve seats too deep will sit the valves "proud" and thus, the valve tip sits up too high making proper valve adjustment difficult... or impossible.
Old Jul 2, 2024 | 08:13 PM
dirt-cheap's Avatar
Yesterday I replaced all 8 valve-stem seals. So I figured i should adjust the valves as well. The engine was running perfect before that except I noticed oil on the spark-plugs and in the spark-plug wells. Probably just the spark-plug seals under the valve cover, but I thought I would replace the valve-stem seals as well. Now the #1 intake valve has no adjustment clearance at all.
What could have happened?
If by chance I'm actually on #4 intake compression would that effect the #1 intake clearance if I accidentally have #1 on exhaust stroke rather than compression stroke?
white_n_slow
May 15, 2005 07:51 PM
.water
Sep 18, 2004 04:10 AM
