Shift linkage slop
Linkage moves side to side even in gear, replaced the busing and there isn’t any slop in the joint. Before I put the s40 b000 in the car I noticed the pin the shifter connected too did not want to spring back to the middle when I put a screwdriver through the hole where the bi*** pin should go and shook it left to right as if I was “shaking the shifter”. Anyone know what part that little joint on the transmission is and how easy it would be to replace it or another way to fix that slop?
JDM_ego2033
Nov 22, 2021 09:17 AM
WGFletch4WS
Jun 6, 2011 05:55 PM
