Honda CR-V & Element 2WD & 4WD Element & CR-V
What I've tried to fix the CRV trans shudder
Old Jun 14, 2024 | 11:24 AM
bearded's Avatar
Default What I've tried to fix the CRV trans shudder
Hi Guys,
I'm working on the dreaded CRV (2014) trans shudder. I've...
- drained and filled 3x with Honda fluid (twice)
- checked and cleaned shift solenoids A & B (screens clean, action good, ohms in range)
- checked and cleaned the ground connection on the trans
- got the computer updated
It still shudders intermittently around 25mph and 35mph going uphill.
Is there anything else I should try before going ahead and spending a couple thousand to get the torque converter replaced?
And if I replace the T/C will that fix it?
Thanks for your help.
Old Jun 14, 2024 | 10:26 PM
chidog's Avatar
Default Re: What I've tried to fix the CRV trans shudder
I guess 2015 all CRV's went CVT, so not sure when that was offered.
If its a normal conventional step transmission, I guess they can have the torque converter clutch slip deal.
I'd be doing an actual pressure test to see if it is a pressure loss, and decide from there.
Old Jun 17, 2024 | 09:25 AM
bearded's Avatar
Thanks for the idea.
Old Jun 30, 2024 | 01:09 PM
hondadriver's Avatar
Our 2012 had the same issue. Honda first tried some reprogramming with no change, then a full transmission flush with no change and last was a new Torque convertor that solved the issue. This was all covered by Honda at the time.
Old Jun 30, 2024 | 05:32 PM
bearded's Avatar
Thanks.
I just discovered that my mechanic didn't do a full swap on the fluid - only got about a 1/3 drained. So I'm going to do a full 3x drain and fill and see what happens.
Old Jul 1, 2024 | 06:06 AM
Ryanthegreat1's Avatar
Originally Posted by bearded
Thanks.
Don't waste your time and money, it's still going to shudder.
The fix is a new torque converter.
Old Jul 1, 2024 | 08:11 PM
chidog's Avatar
And what is everyone replacing them with? OEM?
jmh51193
Jan 12, 2015 04:21 PM
wmflyfisher
Dec 9, 2012 12:28 PM
nghtshd88
Apr 30, 2011 06:55 PM
spriddle
Transmission & Drivetrain
Dec 11, 2008 11:18 AM
Probot
Jan 2, 2008 06:26 AM
