Electrical question....
92-95 civic
climate control and radio lights are out. ashtray light isnt. radio works.
i find it hard to believe that ALL the lights are out. Can anyone tell me
which circuit these are on? Anyone ever fix this problem before?
Check the fuses underneath the steering wheel. There should be a couple of fuses...I'm not sure of the names, but check the cig. fuse, running light fuse, dome fuse, and some other stuff that have to do with electrical interior..I do believe there is one underneath the hood as well marked, "Backup" fuse or something....All fuses you should be looking for SHOULD be 10amp fuses..Good Luck
It could be your dimmer ( dash lights brightness controller) switch. I think everything you mentioned is controled by that. I don't think the ashtray light has a dimming signal.
Thanks for the response.
I havent checked the fuses yet, though i looked at the fuse diagram.
I thought interior light would be the dome light.
as far as the dimmer goes, the cluster works so that cant be it i think.
I8ayellowcrayon
21
Sep 1, 2005 01:34 AM
