Y1 Transmission snap ring woes
Old Jun 5, 2024 | 03:23 PM
clicky79's Avatar
5 Year Member
Icon4 Y1 Transmission snap ring woes
absolutely cooked the snap ring for a JDM Y1 Transmission, housing is repaired and bearing has been replaced cannot locate the correct size snap ring, one out of a us LS trans is much too small.
Old Jun 6, 2024 | 11:24 AM
Maxcapacity's Avatar
Default Re: Y1 Transmission snap ring woes
Might have to just get a snap ring kit that has multiple sizes. I see them for around $20.. I'm sure you could use one from a universal kit because it does not have to be precise for size, just as long as it's slightly bigger than the ID of the rings bore.
If you have a 90-91 ls tranny for spare parts, you can do a slight upgrade for the shift forks in your Y1 trans.I used the shift forks from the ls for gears 1st/2nd and 5th since they have more beefier gussets and are a direct swap into the Y1. 3rd/4th gear shift fork does not match. I learned this when I rebuilt my Y1 and had to have my fork brazed with bronze to repair a ring groove on the fork face for 3rd gear shift position.
Old Jun 7, 2024 | 08:55 AM
clicky79's Avatar
5 Year Member
unfortunately its a very odd size at 2 1/4 internal diameter and no kits go that large =/
Old Jun 8, 2024 | 04:05 PM
Tyson's Avatar
Why are you measuring anything on a Honda in inches?
And why don't you just look up the correct part number?
Old Aug 10, 2024 | 06:52 AM
clicky79's Avatar
5 Year Member
sorry for the long delay, but we bought the last one in north America.
eh2_Trav
Transmission & Drivetrain
Sep 24, 2018 09:28 PM
aWeimaraner
Mar 5, 2009 07:26 PM
tegman85
Mar 29, 2006 08:30 PM
LoudAccord
Feb 14, 2002 08:32 AM
