Hi all, I swapped out a knackered shock yesterday. All was going well until I put the new shock in and noticed I can't get get hub up enough to put the second strut to hub nut/bolt in place. I have a feeling the shaft at the engine end may of come out a bit. I've tried a few different scenarios... steering locked either way, jack under the lower control arm, g clamp the shock to the hub to try and close the gap and tried compressing the spring with strut fitted but no joy. Any ideas? Thanks for reading
