Do you need a special lower bolt for exh man heat shield?
Decided to replace my exhaust manifold heat shield since it is corroding away at the bottom. If I ever manage to get the lower bolt removed, what should I replace it with? Is it just a regular bolt or is it specifically heat resistant? Does anyone have a part number? Thank you.
patrick theHman
11
Aug 31, 2009 07:43 AM
