Suspension & Brakes Theory, alignment, spring rates....
01 Acura Integra GS Rear Brake Piston Seized
Old May 27, 2024 | 07:20 AM
feels's Avatar
Default 01 Acura Integra GS Rear Brake Piston Seized
Needs help how to un-seized the rear brake piston. This is a turn-in brake piston instead of press.
I have proper brake piston presser (rotating style) that commonly sell from Amazon, Princess Auto, Harbor Freight, so it is not a heavy duty presser.
The brake piston presser does work in several cars, e.g. Mazda 3, Hyundai, Ford, Honda Odyssey, so I have a good understanding of how much force it uses to press a brake piston.
For this rear brake caliper, the piston is so much rusted that I can't turn it at all. I used a vise grip to run, but can't turn it as well.
I have spray WD-40 into the brake piston's rubber seal but still can't turn with the brake piston presser.
I viewed 2 days of YouTube video about seized brake piston, and no one is sharing much about rotating piston removal.
What other trick the member can share?
Note: I would like to keep the OEM brake caliper for environment-friendly purpose (not to become trash)
Old May 28, 2024 | 11:29 AM
Tyson's Avatar
Default Re: 01 Acura Integra GS Rear Brake Piston Seized
Meh. Either soak it in an unenviromentally friendly tub of evaporust, or just replace it.
Old May 28, 2024 | 12:37 PM
feels's Avatar
Thanks Tyson to share the soaking idea. I will use damp cloth to soak those area. A have 2 acids available, i.e. vinegar and dead battery (HCI) that are environment friendly. 100ml of diluted acid should be enough. Hope not to see the brake caliper to become trash
bryguyphilly
Honda Civic (2016 - Current)
Nov 10, 2021 02:18 PM
leviq
Jul 7, 2007 08:28 AM
117
Jun 22, 2007 08:56 PM
Rguy
Aug 10, 2002 09:12 PM
AzianAvenger
Jun 21, 2002 10:21 AM
