Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
B18b1 help!
Old May 26, 2024 | 01:39 PM
joker1998's Avatar
Default B18b1 help!
This will be my first swap and im curious on everything i will need. I have a 2001 honda civic D series that im going to swap out for the 2001 acura b18b1 motor and a gsr trans and im wonder whats everything i need
Old May 28, 2024 | 04:09 AM
hondamark35's Avatar
Default Re: B18b1 help!
you will need either a 2000 model year or older Civic or a K-series engine.
no one will be able to tell you what you need because no one knowledgeable about doing a swap on a Honda/Acura would choose to do what you're planning.
Old May 28, 2024 | 11:43 AM
joker1998's Avatar
Ok i appreciate that
Old May 28, 2024 | 11:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The "B" series engine/trans would be a really challenging swap... custom mounts would have to be made and the wiring and engine management would be a true nightmare. As stated above... you either need an older ('92-00 Civic) chassis OR find a rear-ended EP3 and move EVERYTHING over from the front of it to your 7G Civic chassis. Beyond the donor EP3, all you would need to buy would be an adapter harness, shifter and shift cables.
killaclownne1
Feb 20, 2014 05:55 PM
pipes70
Feb 12, 2006 07:10 PM
crxSoldado
Nov 21, 2003 06:36 AM
