2000 Accord V6 stripped alternator hole
Old May 14, 2024 | 11:49 AM
St.Nick's Avatar
Default 2000 Accord V6 stripped alternator hole
I got a 2000 accord v6 went to replace the alternator and stripped the hole getting the 14mm out next to the belt tensioner, honestly just trying to figure out where to go from here. I don’t think it’s part of any bolt on could be part of the block I don’t know. Please help!
Old May 14, 2024 | 12:58 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: 2000 Accord V6 stripped alternator hole
Replace the threads with a Helicoil or a Time Sert. The hardest part will probably be drilling out the hole. You would probably need a right angle drill due to the space constraints.
Old May 16, 2024 | 01:00 PM
JDm9898's Avatar
That is also a bracket attached to your engine that you could probably replace. It holds the alternator and water pump but is very accessible and easy to take off from my knowledge. I have an older accord but I would imagine they are similar.
Old May 17, 2024 | 06:53 AM
St.Nick's Avatar
Got all the drill stuff (bit and thread kit) but I don’t have enough clearance. As far as it being a bracket I can’t find anything that says it is or find a way to take it out by looking at it so if anyone has an idea where to go from here I’d appreciate it!
Old May 19, 2024 | 09:13 PM
JDm9898's Avatar
Only thing I can think of is somehow being able to tap it or really carefully trying to rethread it with the screw. Unfortunate situation and hope you get it figured out. Calling some local shops for ideas would also help because they should have some experience with things like this. Best of luck
repeato
Aug 1, 2015 04:04 AM
Tester2k
Jan 29, 2012 07:55 AM
2000 Gold Accord
May 30, 2006 09:49 AM
