Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rpm drop in neutral
Old May 9, 2024 | 06:47 AM
Hunter42's Avatar
Default Rpm drop in neutral
Have changed fuel pump cleaned IACV have to codes for 02 sensor but been on prior to this happening, rpm drop close to 0 sometimes zero when moving and put in neutral, what do I need to look at next scanner says fuel system 0L fault
Old May 22, 2024 | 11:10 AM
Conobtuus's Avatar
Default Re: Rpm drop in neutral
I had a similar situation due to a faulty fuel tank ventilation valve. It caused negative pressure in the fuel tank, leading to RPM dropping to zero. Also, check the throttle body, it might be time for a clean. And make sure the air intake hose hasn't cracked.
Old May 22, 2024 | 11:51 AM
Hunter42's Avatar
It was my ac compressor seizing up so I got a belt for same model with no ac and bypassed it completely no rpm drop now
Old May 22, 2024 | 12:50 PM
Conobtuus's Avatar
Unexpected. Thanks for sharing, I'll keep it in mind
ylekyote
Honda CR-V & Element
Apr 18, 2020 02:04 PM
vtecsi00
15
Aug 22, 2009 02:24 PM
KooK
Nov 28, 2007 01:21 PM
exsinnovation
17
Jun 14, 2006 02:52 PM
96darklude
May 7, 2006 08:50 PM
