1995 honda accord main relay takes forever to engage
Old May 8, 2024 | 11:13 PM
Pungus's Avatar
Default 1995 honda accord main relay takes forever to engage
f22b2 SOHC non v-tec manual that will take anywhere from 10 to 40 minutes to activate the main relay (the CEL stays on until it engages). I recently bought the car off my sister who said she just replaced it, I checked the voltages at the relay and everything seemed okay. Once it engages initially i can turn the keys off and back on and it will usually instantly reengage without the engine running. Once the car is on it runs fine with no CEL or anything. When the engine is warm there is little to no delay, once it cools off it's almost random. Is there anything else I can try or do I just chalk it up to a bad ECU?
Old May 9, 2024 | 07:23 AM
95_civic_gsr's Avatar
Default Re: 1995 honda accord main relay takes forever to engage
Voltages going to, or coming from? Main relays aren't that expensive. It also can be confused with other relays. See if a different one fixes the problem.
Old May 10, 2024 | 09:56 PM
Pungus's Avatar
Honestly not too sure, any help there would be appreciated. I checked at the relay itself and all the voltages were what they should be at the right time at each of the wires.
Old May 11, 2024 | 01:30 AM
Have you tried installing a different main relay? Is the one you have used or brand new?
cleanhonda38
Classic Hondas
Mar 24, 2015 09:52 AM
kitt
Apr 23, 2010 09:00 PM
romeoz24_2000
Aug 12, 2008 04:03 AM
alwaystheking43
Jul 5, 2007 10:48 AM
