1995 Honda Accord Problems
Old May 5, 2024 | 08:42 PM
JDm9898's Avatar
Default 1995 Honda Accord Problems
Hey Guys,
I bought a 1995 Honda Accord from Facebook marketplace and it runs great the tranny is just fine but it seems to have an acceleration problem. I took it to a good family friend mechanic who owns his own shop and he looked at it and said its a great car but so many different things could be causing the slow acceleration and loss of power.
I have since replaced the timing belt, water pump, put in iridium spark plugs, new alternator because the voltage regulator was blown on the last, and air filter. When I accelerate it will go okay but then when I get to normal speeds 20-40 I can press down the glass and there is really no response unless I go full throttle and it has a harsh downshift then will give me some rmps and power. When I am on the highway 50-60mph in 4th gear it will also not want to give me more power and cruise control has a hard time going up hills. AC has also gone out. Any suggestions or help would be much appreciated. Thanks
UPDATE
Just tested with the paperclip and it has a CEL 3 code. This is either my MAP sensor or I was looking at a post and it said TCU 3 is my Throttle Position Sensor circuit open or shorted so I do not know which one it is.
Went to a pick-and-pull and replaced the old sensor for 20$. Still a little slow to accelerate but a whole lot better now. Going to do a can of seafoam and maybe clean my throttle body and intake and check how dirty my valves are.
Car Specs
160k Miles
2.2L F22B2 engine
Old May 8, 2024 | 04:49 PM
JDm9898's Avatar
Default Re: 1995 Honda Accord Problems
if any one has any suggestions that would be appreciated
NothernLights
Jun 7, 2016 07:46 AM
Ord4
Sep 21, 2013 03:10 AM
theguy22
Jun 8, 2012 03:20 PM
prodgerson
Classic Hondas
Dec 19, 2009 03:46 PM
94HondaAccord_LX
Jan 3, 2008 03:46 PM
