Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
2019 Civic Door Lock Cylinder
Old May 5, 2024 | 08:30 AM
HondaNoob2024's Avatar
Default 2019 Civic Door Lock Cylinder
Hello all, I had my dealership run a diagnostic on my car because my driver side door wouldn't lock. They said the door lock cylinder needs to be replaced. I ordered the part and removed the old door lock cylinder. When I installed the new one, the lock works when I use my key fob but when I use the key that came with the new part, it does not work to lock or unlock the door. So essentially I can only lock and unlock my car with the key fob but not with the physical key. Any idea what the issue might be? Is it that the key lock cylinder isnt lining up in the little white X looking part? I don't know how I can ensure that it does because you can only insert the cylinder one way and try to line it up with the part where you bolt it in (which I;ve done). I'm not sure what else I can do.
Any advice is appreciated. TIA.
jqtnenn
Nov 20, 2022 12:16 PM
Dyingdevil87
Jul 13, 2022 05:51 PM
davideric05
Honda CR-V & Element
Dec 6, 2019 08:46 AM
tmoor
Dec 10, 2011 05:59 AM
renegadez7o7
Jun 6, 2006 04:55 PM
