F18B Stroker ECU
Old May 1, 2024 | 03:07 AM
teental16's Avatar
Default F18B Stroker ECU
Hello Everyone
I would like to use an F22/23 crank and rods in an F18B block [CD3 1996 ODB1], however I would like to avoid a standalone ECU by keeping the compression ratio the same as a stock Accord and use a stock Accord Manual ECU.
Is this possible? If I keep the compression ratio and CC the same, can I use a matching stock ECU? I don't want the hassle\price of tuning etc, I just need the extra grunt of an F22/F23
Thank you!
Old May 1, 2024 | 10:36 AM
Aradin's Avatar
Premium Member
Default Re: F18B Stroker ECU
Yes. You would use an F22A/B crank and rods, as the F23 crank has 55mm mains and is not compatible for that reason and others.
I am guessing you can just source a USDM OBD1 F22B2 ECU and it would be plug and play. Just make sure to use the appropriate 240cc low impedance injectors. I am not intimately familiar with the market for the CD3/F18B and am unsure if there are any major electronic differences so I can't say for sure. You would have to do your own research on that.
Old May 1, 2024 | 11:33 AM
teental16's Avatar
Thanks Aradin
I have read that the main journals in the F18B is 55mm, and I have access to F23 crank which is the same. The plan is to machine the F23 crank to 50mm mains if necessary. What do you think ? Any other reason why the F23 crank would not work?
My engine has F18B stamped on the block, I have not yet dismantled as its my daily, so don't know for sure main journal size
Thanks again
Old May 2, 2024 | 06:56 PM
nicolaselias's Avatar
Loved
Community Favorite
Interesting project there. The question I have is what is your aim and goal for it? What are you looking for by stroking it out etc? More power?
Bradz96
Engine Management and Tuning
Jan 7, 2018 07:14 AM
CD8coupeSiR
Sep 1, 2006 08:55 PM
f22btwincam
Nov 25, 2002 06:18 AM
