Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 CRV idle problems after replacing IAC valve and cleaning throttle body
Old Apr 29, 2024 | 09:54 AM
phylban's Avatar
Default 2003 CRV idle problems after replacing IAC valve and cleaning throttle body
Had a check engine light which gave out a code p0505. I checked the IAC valve which looked worn and replaced it with a new one. Now when I start the car it starts at a high idle (around 1.5k to 2.5k) before going down to around 1250 rpm and after about a minute it sounds like it’s doing short revs. Also when I’m around parking lot speeds the car starts jerking back and forth.
Most google searches lead me to believe there’s a vacuum leak however after doing the carb cleaner test I can’t seem to find any. The engine light also didn’t go away.
Old May 6, 2024 | 02:55 PM
srom's Avatar
Default Re: 2003 CRV idle problems after replacing IAC valve and cleaning throttle body
A few of things come to mind:
- check the connectors are fully mated. The IACV connector is tucked under on the lower left of the TB. I had a code when I forgot to connect it.
- disconnect the connectors and spray them with electronic cleaner. Allow them to dry before reconnecting.
- check and follow the small hoses above the TB to each end
Old May 6, 2024 | 11:05 PM
95_civic_gsr's Avatar
Have you done an idle relearn process?
a quick google search turned this up, second post:
https://www.crvownersclub.com/thread...cedure.124522/
meandino
Dec 16, 2020 07:40 AM
sullins
Jul 11, 2011 03:36 PM
m00nr0ck Si
Apr 1, 2009 04:17 PM
accordfreak
Aug 30, 2003 01:26 AM
Excelerate
May 7, 2003 02:13 PM
