FS: Custom made inner trunk gate; Back Seat Back Support Substitute
Old Apr 25, 2024 | 07:27 AM
k3ntegra's Avatar
Loved
Community Favorite
Default FS: Custom made inner trunk gate; Back Seat Back Support Substitute
Purpose of this custom made addon, was to allow me to fully extend my legs while
lying down. Lying directly on the folded seat caused damage to it.
I did not have to drill new holes into the car's metal frame/body, nor did I have to add a weld nut; it's a straight bolt on with 6mm diameter bolts.
The gate uses three 'spring loaded' hinges, meaning the door stays open fully when latch is lifted.
My car was involved in an accident, and unfortuntely had to be written off.
This explains the piece of wood snapped off. I have the wood on hand and can be 'wood glued' back if one wishes. Some of the aluminum angles were bent. One may be able to bend them back into place with a hammer and such. Hench I make no guarantee they will fit without some adjustment.
If you've never used a drill power tool, I would advise against buying this.
This is for a 2001 Acura Integra GS Coupe 3-Door Hatchback.
Shipping specfication:
Dimension: 44x18x7 inches
Weight: 10 lbs
Baltimore to Los Angeles (90001 zip code) Shipping estimated fee are
FedEx: $110, UPS: $103, & USPS: $131
Uship.com wasn't any cheaper.
Asking $65 + shipping.
Image links, forum won't display imgur links directly. Imgur links are higher resolution.
Code:
https://i.imgur.com/UTLFct5.png
https://i.imgur.com/VT9b03F.png
https://i.imgur.com/I2yEkqJ.jpeg
SHG_EasyE
Feb 14, 2014 07:38 PM
frankenwabbit
Sep 15, 2006 07:25 AM
H5Civic
May 28, 2004 06:54 AM
