D16Y8 Distributor Rotor Removal
Old Apr 22, 2024 | 12:44 PM
SOHCAdrian's Avatar
Default D16Y8 Distributor Rotor Removal
Does anyones know how to take out this rotor? Its a D16Y8 head. I try looking for the screw buts its not there.
Old Apr 22, 2024 | 03:53 PM
Maxcapacity's Avatar
Default Re: D16Y8 Distributor Rotor Removal
You might have solved your issue by now but for simplicity, make a mark -fine line across the top mounting ear of the distributor to the head and then just remove the distributor. It will be much easier to access the rotor screw than doing light "cranks" to get it to align with the internal plastic cover. Once done replacement, just bolt the dizzy back on and align the timing mark you made previously and should be good to go!
(Would be wise to replace the o-ring on the distributor while it's out)
BradleyBaynard
Feb 21, 2022 05:13 AM
92civicsi
May 24, 2011 04:06 PM
rhdekhatchie
Jan 23, 2008 10:04 AM
im a monster hehe
Jun 23, 2007 03:56 PM
