AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
hypothetical regaurding wagovan diff
Old Apr 17, 2024 | 03:20 PM
beefystud's Avatar
Default hypothetical regaurding wagovan diff
hypothetical question: what would happen if you had the crv k20 transmission connected to a wagovan 4wd diff with a strait custom drive shaft drive shaft , no viscous coupler , would the diff be engaged at all times ? or would the whole drive chain just explode ?
Old Apr 18, 2024 | 06:32 AM
Ryanthegreat1's Avatar
Default Re: hypothetical regaurding wagovan diff
Correct, you will have binding in that configuration leading to the finding of the weak link. Probably the transfer case bolted to the transmission.
You need something in the system to allow the front and rear axles to operate at different speeds.
brewerkz
Honda CR-V & Element
Nov 28, 2017 08:40 PM
wasanissanFL
Transmission & Drivetrain
Feb 4, 2016 01:37 PM
spontaneous ep3
Aug 29, 2004 01:49 PM
