Honda CR-V & Element 2WD & 4WD Element & CR-V
Are the valves open when at tdc?
Old Apr 14, 2024 | 06:38 AM
cncDean's Avatar
Default Are the valves open when at tdc?
I’m fairly certain that they are but I’ve seen videos with them all closed.
I have a 2001 crv. The timing belt broke and there was carbon marks in the valves where the pistons hit.
I sent it to the shop and replaced all the valves.
im about to install it in the block but noticed that 2 exhaust valves on cyl 2 are open slightly and 2 intake valves on 3 are open.
is this normal?
if anyone wonders why there are 4 different colored exhaust valves, it’s because I order from rockauto and got confused when it said x2 and thought I was getting 2 for that price. Turns out it means minimum of 2 because they come in the box with 2.
Old Apr 14, 2024 | 07:01 AM
cncDean's Avatar
Default Re: Are the valves open when at tdc?
So what I was seeing when all the valves were closed, was a head with no cams in it.
Old Apr 16, 2024 | 12:54 PM
chidog's Avatar
Yes they are at overlap. Not in firing though.
namewasdallas
15
Apr 30, 2011 04:14 AM
guy_from_nerk
May 12, 2006 11:29 PM
jdmkrazie
Jan 12, 2004 07:15 AM
Riptide101
Apr 1, 2003 08:43 AM
