Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2015 Accord 4 Cylinder Idle Speeds
Old Apr 6, 2024 | 04:35 PM
agaccord's Avatar
Default 2015 Accord 4 Cylinder Idle Speeds
Hello.
What are the official start-up and warm idle speeds? Apologies if the answer is in an existing thread. I searched the forums, but didn't find them.
Thanks,
Alan
Old Apr 24, 2024 | 01:09 PM
davisj77's Avatar
Default Re: 2015 Accord 4 Cylinder Idle Speeds
Pretty sure cold start idle will depend on how cold it is outside but somewhere around 1100-1500 RPM initially, then it will drop. Warm idle in park foot off the brake should be 700-800.
Old Apr 26, 2024 | 03:26 PM
agaccord's Avatar
Thank you. That's the idle speeds I show.
I replaced the throttle body, and mileage dropped from combined average of 26-27 to 21-24. Thought it might be idle issue, which feels higher that what I remember. Any thoughts on causes of mileage drop after replacing a throttle body?
Old Apr 26, 2024 | 03:39 PM
davisj77's Avatar
I would try a new air filter first. You may need to reset the throttle position sensor with a bidirectional scan tool. I would check the fuel trims with it too.
Old Apr 26, 2024 | 05:03 PM
agaccord's Avatar
Thanks for the detailed info.
philosofy1
Jan 31, 2008 10:58 PM
rcjordan5749
Jul 16, 2007 11:37 AM
NewfieAccordEXR
May 24, 2006 10:21 AM
hluuci
Jun 9, 2004 05:43 AM
