Engine swap v6 to 4cylinder
Old Apr 3, 2024 | 12:11 PM
Siktown's Avatar
Default Engine swap v6 to 4cylinder
I have a 1997 Accord with the awful 2.7 v6 that’s knocking. I was wanting to do a swap over to the original 4 cylinder. I would assume if I change out the engine sub harness from a 1997 4 cylinder accord and change the ecu that should get me close. Anybody else down this and know what else I may need to do or change, main wiring harness as well?
Old Apr 3, 2024 | 02:47 PM
Aradin's Avatar
Premium Member
Default Re: Engine swap v6 to 4cylinder
You would need a lot more than that...The engine bays are completely different, dash harnesses/cluster differences, ECU, etc etc etc. You would basically need an entire donor car with a 4 cylinder and even then it would require cutting/welding mount brackets amongst other things. Might as well just get another car at that point.
Kienan
Sep 8, 2022 07:38 AM
Cd5Frankie
Dec 31, 2021 03:26 PM
Weslay23
Classic Hondas
Mar 10, 2017 09:03 PM
low13da9
Sep 27, 2012 04:00 PM
